help on surface subtracting
Old   February 28, 2004, 12:16
Default help on surface subtracting
john
Hello all,
I'm having problems with faces subtracting. my model represents an external steady state flow past a hemisphere so I've built 2D axisymmetric model. In order to mesh certain faces finer than others I'v subtracted those faces from the main face, and meshed them one by one. I didn't specified any boundary conditions on the edges dividing between the inner faces nor used virtual edges (I've been advised not to do so). After I examined the solution I saw the surfaces aren't connected together, the flow occurs in each surface separately (even when I tried to use virtual edges). Does anyone know what seems to be the problem ?
Another question is about using the acoustic analysis feature in Fluent 6.1. If I want to find the flow noise over the hemisphere, what kind of sources should I use ?
Thanks in advance, John
Old   February 29, 2004, 09:47
Default Re: help on surface subtracting
mateus
Hi!
When you split the surface you probabilly become an extra edge. One edge for the left and one for the right surface. Fluent then treats an extra edge as exterior edge and automaticlly defines a wall bc on it. It it better to make edges first, and the select edges to create a surface. This way the left and right surface will share the middle edge and you won't have this problem any more.
regards
mateus
Old   February 29, 2004, 11:20
john
thnaks!
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
