Joining Files in Gambit
Old   February 19, 2004, 08:57
Default Joining Files in Gambit
jens
Hello I have got different Gambit Files. Each with a geometry I need for a new project. How can I join the data from three different files in one gambit file?
Hope you understand and thanks for helping.
jens
Old   February 20, 2004, 06:50
Default Re: Joining Files in Gambit
MM
you shoule export one of files as a ACIS file. open your second dbs geometry and import the acis file.
Old   February 20, 2004, 07:28
jens
Thanks for your answer. I tried, but Gambit exports only three faces, not the whole geometry. Or do I have to remove the mesh? jens
Old   February 22, 2004, 15:52
MM
you can only join the geometry with this method. I don't know a method for joining mesh too. If anyone has an idea i will be happy to hear it. MM
Old   February 23, 2004, 03:50
jens
hello
I tried to import the mesh. Export Mesh and than import mesh.
it works. you can import the mesh data and Gambit knows all geometry data including faces and volumes.
jens
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 07:28
reading gambit mesh files using fortran zonexo FLUENT 4 December 15, 2020 13:39
Importing IGES files into GAMBIT and meshing kartik FLUENT 3 September 23, 2008 01:12
Gambit input files Riaan FLUENT 1 January 14, 2005 10:12
open mesh files in gambit A.Naser FLUENT 3 February 20, 2004 06:39
