February 12, 2004, 04:55 |
Help!!!error message from graphics
Hi, all,
I have problem with the residuals monitor---after I read my case and data file, I pressed plot/residuals, but I got the following error messages: Error message from graphics function Update_Display: Unable to Set OpenGL Rendering Context Error: FLUENT received a fatal signal(SEGMENTATION VIOLATION) Error Object) Any suggestion is pretty appreciated. Emma |
February 14, 2004, 05:08 |
Re: Help!!!error message from graphics
Don't know if this will help, but I was getting similar errors when opening graphics windows (Running Fluent on WinXP). Turning graphics hardware acceleration down worked for me. To do this right click on your desktop then click properties>settings>advanced>troubleshoot then move the slider down until fluent doesn't crash (moving down 3 notches worked for me). Hope this helps!
James. |
February 14, 2004, 08:44 |
i had some problems with a graphic card before (couldnt see any figures and grids) and i could fix it by starting Fluent with the command: /pathtoyourfluent.exe/fluent.exe -driver msw
(which sets the graphics driver to the microsoft driver as far as i know) maybe this helps... Stefan |
February 15, 2004, 06:27 |
Do u have matlab installed too? Might be the problem if it is, u have to remove the Matlab web server starting when the computer start.
Nico |
February 16, 2004, 10:42 |
Hi, James, Stefan and Nico,
Thanks alot for your quick replies! I will try them to see which works on my computer. Regards, Emma |
February 17, 2004, 04:29 |
hi, Stefan,
I tried to solve the problem in the way you told me, it works now, thanks alot!!! Regards, Emma |
ANIMATIONS IN BATCH MODE | Arianna | FLUENT | 1 | January 31, 2008 10:04 |
Graphics Problem | Ryan | FLUENT | 0 | January 18, 2006 10:57 |
error message from graphics func. Update_Display | Manish | FLUENT | 3 | April 8, 2005 05:38 |
How to change and fix the size of graphics window? | Rob | FLUENT | 1 | February 7, 2003 11:15 |
Problem: graphics display in prostar main window | Jiaying Xu | Siemens | 8 | February 14, 2002 09:08 |
