Help on run fluent jou file
Old   February 11, 2004, 16:22
Default Help on run fluent jou file
Jack Liang
I bulit a fluent jou file by using start Jounal file and stop jou file in the file menu.
this is part of the file I built, the file name is sample.jou : ************************************************** **** (cx-gui-do cx-activate-item "MenuBar*ReadSubMenu*Case & Data...") (cx-gui-do cx-set-text-entry "Select File*FilterText" "*.cas*") ************************************************** *
Since I am not intending to read my "sample.jou" file from the file menu, I want it to be run in background, so I typed command:
fluent 3d -g -i sample.jou
it gives me an error like this: ************************************************ Error: No GUI functions are available. Error Object: () (cx-gui-do cx-activate-item "MenuBar*ReadSubMenu*Case & Data...") ************************************************
Anyone can tell me how to solve this problem? thanks.
Old   February 11, 2004, 18:57
Default Re: Help on run fluent jou file
Rob Hart
yep.
If you want your journal file to run for a background job, then you can only use the text-mode interface when you record it.
So rather than click on the file menu, and selecting read... then case & data, you type: file/read-case-data "myfile.cas"
There are text equivalents of pretty much all the GUI, and there are even a few things that you can only get at through the text interface.
Hope that helps.
Rob
Old   February 13, 2004, 22:08
esteban
Try the same example but typing: fluent 3d -i sample.jou (do not include -g) the -g command disables the graphic options, that is why you weren't able to run GUI commands (Graphic User Interface)
Hope that helps
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
