February 10, 2004, 08:09 |
FLUENT doesn´t work !
Hello: I work with sails, and i use it as parachute. I think in this case all the force over the surface must be from viscous terms ( no too much ciculation arround the sail appear), but when i make a force report the viscous force is very smaller than the pressure force. Does anyone knows why?
Other problem is that the pressure force on the sail and the sail shadow are of the same direction, and i think they must pe opossite. When this problem appear i put a wall in a down stream inviscid flow, and the Dalambert paradox doesnt appear, There was force!. There are too many things i dont understand. Can anyone help me please? Thanks |
February 24, 2004, 13:57 |
Re: FLUENT doesn´t work !
The dpm model has a minimum diameter for particles, I believe 1e-8 m. Try setting your particle size to 2e-8. If not acceptable for your model, I suggest contacting Fluent, there may be something you can change in a header file to decrease the minimum diameter.
Exporting structured mesh from ICEMCFD to Fluent? | jeevan kumar | FLUENT | 1 | January 23, 2012 12:21 |
udf fluent 6.3.26 don't work in fluent 12 | enry | Fluent UDF and Scheme Programming | 16 | September 9, 2010 03:44 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 13:07 |
How does Fluent RANS model work? | Tang Jingwei | FLUENT | 6 | August 22, 2009 16:08 |
Fluent does not work on openSUSE 11.0 | Stanislav Sviderek | FLUENT | 1 | July 28, 2008 18:21 |
