Influence of Y+ value
Old   February 6, 2004, 08:03
Default Influence of Y+ value
xiang
I am applying Standard wall function in my simulation. After the first try, I found Y+ values in some regions were out of the range of 30-60. Then I adapted the near wall grid with Y+ adaption (min. 30 and max. 60). The cell number increased by around 3000 after adaptation. Then I iterated again until convergence was obtained. But when I compared the velocity distribution between these two runs, it showed only negligible difference. Is this possible or I am doing anything wrong? Thanks for all your opions.
Old   February 6, 2004, 14:02
Default Re: Influence of Y+ value
Melih GULEREN
Did you look near-wall or mean flow profile? I think, if you look near-wall by a log-scale, you will see the difference...
Regards
Old   February 6, 2004, 20:27
xiang
Old   February 6, 2004, 20:31
xiang
Thank you very much. I will look into the near wall carefully.
Gravity (g) Influence on Simulation Results Colin FLUENT 12 September 23, 2015 10:45
Region on influence in ansys meshing ATOTA ANSYS Meshing & Geometry 0 November 17, 2010 16:31
influence of the hydrostatic pressure pdz711 FLUENT 0 June 16, 2008 04:38
influence clogging in porous media budiharto FLUENT 0 July 27, 2005 10:06
Gravity g's influence on Simulation Results Colin Main CFD Forum 6 November 2, 2003 15:13
