guidelines on time step
Old   February 3, 2004, 21:36
Default guidelines on time step
Effendi Ali
hi all, to be straight to the point, my simulation is about boiling. i have problem on deciding the correct time step, since different time step will vary the simulation result (although on the same flow time)
example: 1 time step of 1s 10 time step of 0.1s 100 time step of 0.01s and 1000 time step of 0.001s all of it will generate different result
please enlighten me
thanks you in advance
Old   February 4, 2004, 03:41
Default Re: guidelines on time step
mateus
Hi!
Do all simulations converge? In principle the right time step should be about 100 times smaller then the (1/igenfrequency) of the phenomenon. At least that's my experience... Check out the courant number also..
regards
MATEUS
Old   February 4, 2004, 07:15
prasanth
hai Ali and mateus, I am also facing the same problem. mateus, yeah for some time steps it will converge. some cases wont. according to you, how to calculate courant number for two-phase problem? I kknow general formula for courant number.'
thnks and rgds prasanth
Old   February 4, 2004, 08:50
Effendi Ali
thanx for your response mateus and prasanth
yes it is converge for every single time step (i make sure there are enough iterations per time step)
HELP! time step too small? meangreen Main CFD Forum 6 May 31, 2018 11:41
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 23:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
