January 30, 2004, 13:22 |
Radial plane
Hi all,
I want to determine the mass flow rate radially across a tube. I have constructed the domain using a cartensian coordinate system, needed to this for another part of the domain. My question is: Is it possible to construct a cylindrical plane within the domain so that Fluent can calculate the mass flow rate across a radial zones I want to create? Thanx, Eric |
Using a Plane id in Fluent UDF | cdf_user | Fluent UDF and Scheme Programming | 13 | October 17, 2023 00:06 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 17:08 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 07:16 |
