drag coeffecient of a single cylinder
Old   January 27, 2004, 11:05
Default drag coeffecient of a single cylinder
Allan
all the text books and references seem to suggest that the drag coeffecient for a circular cylinder for reynolds number 10000, 100000 are about 1.2 approximtely. but when i am using flent i get values of about 0.1- 0.2 (max). i dont seem to understand whats going wrong. i have consulted some people in this area but they tell me that i am right and they cant figure why fluent is giving me such weird values. please help me out here as i am in deep trouble and have a deadline to submit. thanking you. allan
Old   January 27, 2004, 12:02
Default Re: drag coeffecient of a single cylinder
ace
Allan you might find it helpful to look at the reference values you give in the panel since the coefficients depend on them as well.
Also try different turbulence models......
Hope it resolves your problem.
Cheers....
Old   January 27, 2004, 23:46
Anton
Yes, check the reference values that are being used to calculate lift and drag coefficients. There are default values like L=1m, etc. You have to change these to the appropriate values for your system.
Old   January 30, 2004, 02:16
Qureshi
I guess the problem is still there, One can change and play around with the parameters to get the results to ones liking. There has to be some standard methodology so that whenever one intend to carry out analysis on shapes and configurations with unknown results. Can anyone throw some light on it?
Old   February 3, 2004, 11:46
Allan
I contacted the Fluent engineer, who told me to increase the depth in the reference values to 10.
This increased the CD to the desired value (around 1). However, when I increase the flow velocity from the original value, the CD jumped to over 9000 (it should be around 0.3).
You can easily get the CD to the value you want by altering the depth value, but this isn't right.
Does anyone know if there is a standard method to find the correct depth value?
Drag Coefficient Verification around Cylinder MFerris CFX 44 May 11, 2015 19:27
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Drag on non-infinite cylinder between parallel walls deltaquattro Main CFD Forum 0 September 10, 2009 14:01
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 11:50
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
