UDF
Old   January 26, 2004, 02:04
Default UDF
maryam
Hi, How can I use UDF in Fluent? What should I do?
Thanks
Old   January 26, 2004, 04:44
Default Re: UDF
mateus
Hi!
I'm not shure what you are asking. If you don't know how to write an udf, you should first read Fluent UDF documentation to get the idea what you can do with udfs. There is a lot of examples, tutorials and other usefull stuff to read.
If you allready have a udf and don't know how to put it Fluent you should go to Define-User Define-functions-iterpreted...then you select your function and it becomes a part of Fluent. If you (for example) make a udf velocity you have to select your function at velocity inlet bc... but read the manual for more info.
Why do you need a udf? Usually (for simpler simualtions) you don't need to use it.
Hope I helped...
MATEUS
Old   January 27, 2004, 01:53
Default Re: UDF
maryam
Hi mateus, Thank you for your comment. My boundary conditions depend on Grashof number and I have to specify it, do I need to use UDF? If so,please tell me should I do anything for install this part of fluent? Thank you
Old   January 27, 2004, 08:03
Default Re: UDF
mateus
Hi!
If I understand correctly you want to calculete the grashoff number from a converged solution (you take the temperature and velocity) and then use the result in some equation that defines the new bounary condition. Am I right.
I think you can do this with an udf. Check out the documentation, for example:
http://www.engr.subr.edu/Support/flu...df/node206.htm
have fun
MATEUS
Old   January 28, 2004, 01:20
Default Re: UDF
maryam
I will try to do it.
Good luck
Maryam
Old   January 30, 2004, 01:34
Default Re: UDF
maryam
hi
should I have mesh independent results for publishing?
for example I want to compare The nusselt numbers
with previuos works,
Is it important that they wouldn't change with grid
size?
Thank you
bye
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
