DPM problem
Old   January 23, 2004, 11:54
Default DPM problem
Jane
I am using discrete phase modeling to simulate the particle trajectory. I have a question regarding how to save the particle trajectory to a file. Since I use the surface injection, that means around 100 particles will be injected from the inlet surface. In the DPM the Maximum number of steps was set as 50000. Then in the particle tracks, I used step to step to track the particles and write trajectory report to a file. It turns out that the file is so big (300MB), because the files contains almost everything eg. Time, X-position, Y-position, U-Velocity, V-velocity, W-velocity, Temperature, Density and mass for each step. Actually all what I need is just the Y-position (the radial coordinate) of the particles at the outlet. I don¡¯t care about what is going on between the inlet and the outlet. But I really can¡¯t figure out how to report only the radial coordinate of the particles at the outlet to a file. If anybody has a idea, please let me know. Thank you very much!
Jane
Old   January 26, 2004, 03:38
Default Re: DPM problem
groni
Hi Jane, I would suggest that you write a UDF function which prints your y-coordinate in a file. I would suggest that you use the DEFINE_DPM_SCALAR_UPDATE -macro as interface because this macro will be executed by fluent each dpm iteration.
Günter
Old   February 9, 2004, 08:34
Devy
Hello
Do you have any case about this DEFINE_DPM_SCALAR_UPDATE -macro ?
Would you like to send me a copy?
Thank you
Old   February 9, 2004, 09:23
groni
Here's a small example:
DEFINE_DPM_SCALAR_UPDATE(ODE_INT_RK4, c, t, initialize, p) { FILE *fpointer;
if (initialize == 1) {
//Initialisierung der Anfangsrotation
p->user[0]=0.0; // Drehung um x-Achse
p->user[1]=0.0; // Drehung um y-Achse
p->user[2]=0.0; // Drehung um z-Achse
//write a header in file test.txt
fpointer = fopen("test.txt", "a");
fprintf(fpointer, " Partikelzeit, Omega_x, Omega_y, Omega_z \n");
fclose(fpointer); } else { // here are normally other calculations
//write values in test.txt
fprintf(fpointer, "%20.5f, %20.5f, %20.5f, %20.5f \n", P_TIME(p), P_USER_REAL(p,0), P_USER_REAL(p,1), P_USER_REAL(p,2));
fclose(fpointer); } }
yours groni
Old   February 20, 2004, 04:24
Karthick
Hello Jane
I am also dealing with some type of same problem. I am also sending say 20 particles of some size. But I want to include particle-particle interaction also. Is it possible to include particle-particle interaction in Fluent. Also how u are tracking each particle. I am trying to track each particle, but I am not getting it..
Regards - Karthick
DPM Parcel Number Problem Shane FLUENT 7 October 25, 2012 09:24
DPM Output Problem (Again...) DLINSA Fluent UDF and Scheme Programming 1 March 16, 2012 01:45
Problem in DPM Harpreet FLUENT 0 July 31, 2011 10:56
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
