Parallel and series fluent
Old   January 21, 2004, 09:48
Default Parallel and series fluent
Stan Tonks
Hi, I'm getting slightly different results when running a comparative case in Fluent6.1, on a single processor, and in parallel on two processors. Does anyone have any experience of this happening and how to cure the problem? Ta, Stan
Old   January 29, 2004, 13:00
Default Re: Parallel and series fluent
David Jones
It is not an important problem and naturally parallel and serial fluent give different results. Do you run parallel fluent on windows or linux or other cluster?
MPI Crashes After FMG Solver - Parallel computing on Linux jonny_b FLUENT 0 April 11, 2011 13:36
how to change series UDF to Parallel UDF zhang.limin FLUENT 0 January 25, 2011 15:27
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Help with Define on Demand UDF in Parallel Mahesh FLUENT 2 August 7, 2007 06:34
Face loop in a Parallel UDF Dario FLUENT 4 May 10, 2007 09:34
