Multiphase Multicomponent
Old   January 19, 2004, 01:49
Default Multiphase Multicomponent
David
Hello, all:
What version of Fluent can treat a multiphase multicomponent system with more than 5 components in one phase as well as some chemical reactions in one phase? Very urgent, thanks a lot beforehand.
David
Old   January 19, 2004, 03:59
Default Re: Multiphase Multicomponent
TAMO2
Hello, if you cannot use Fluent in this case, as default.
If you want to use in this case, you must program UDF. (Perhaps..., now I contact Fluent support center. IF I get the answer, I will write the answer.)
Old   January 19, 2004, 06:04
TAMO2(from Japan)
I get the answer from user support center.
You must apply components to User Defined Scalar(UDSI).
And perhaps, in Fluent Ver.6.2 or Ver.7 we can use this function--using components in multiphase-- as default.
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 06:29
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 21:15
multiphase and multicomponent flow charles CFX 2 December 18, 2008 22:34
multiphase or multicomponent.... That's the probl july Siemens 1 March 7, 2002 03:27
Multiphase or Multicomponent Pandu Sattvika CFX 10 January 7, 2002 05:40
