Turbulence Model for flow between corotating disk |
Which turbulence model is recommended for the following case?
Flow between corotating disks, specially attention that the gap is very thin b << r (b=gap, r=radius) ro/b=200 ro/ri=6, (i=inner, o=outer) Re-b= 30 (reynolds associated to the gap and circumferential outer tangential speed) Re-l = 6500 (local reynolds local at circumferential station associated to the radius and tangential speed) One similar model can be visualized in the following page http://www.fast.u-psud.fr/~moisy/papers/gau_jfm02.pdf Just to have into account that for my case is a open system in which the flow enter at the pheriphery and exhaust at the inner radius. What about damping from Low re ke to High Re ke Models? I mean : two simulations -one with high Re and other with low Re ke-, or two regions of the flow an inner and and outer. I am using fluent. I thank in advance for the suggestions and opinions. Best regards Felipe Rey |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Adding a Turbulence Model | doug | OpenFOAM Running, Solving & CFD | 11 | May 21, 2018 13:54 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Fan heater model: what turbulence source to use? | andy20 | CFX | 7 | March 3, 2008 16:42 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 16:15 |
