January 9, 2004, 12:14 |
periodic fully developed flow in pipe
I am trying to do a very basic simulation. It is to obtain fully developed flow in a pipe of constant cross section.I want to biuld the mesh so that there are periodic bcs. This way I don't need to biuld a very long pipe.
How do I build such a mesh? I have tried linking the in and out and then meshing. However, the resulting mesh is only on the faces and the pipe wall, not in the volume even though I requested a volume mesh. Can anyone help with this very simple dilema? Thanks |
January 12, 2004, 04:12 |
Re: periodic fully developed flow in pipe
well, periodic, I assume that you are doing a 3D problem, if you request a volume mesh in gambit, then you should either get a volume mesh or an error tell you why a mesh has not been generated in the bottom part of the screen. What is the error you are recieving?
January 12, 2004, 06:58 |
Yes. 3D pipe. When I have not mesh on a face and request a volume mesh the error is: Face.1 could not be converted to a submappable region.
When I first mesh a face and then request a mesh of the volume I get the same error. I'm not sure what I'm doing wrong. I just want to have a 3D pipe with periodic bcs so I can obtain fd flow profile. |
January 12, 2004, 09:38 |
is there any hole in face 1. are number of nodes equal on opposite sides?
January 12, 2004, 11:53 |
There does not appear to be any hole in the face. The number of nodes are the same on both faces.
To create the geometry I simply chose to create a volume on a predefined primative, choosing cylinder. Then I go to mesh and choose to mesh the first end face. Then go to mesh the volume choosing the volume and the meshed end face as the source. I get the same error. What am I doing wrong? |
January 12, 2004, 15:57 |
My preferred way to mesh any cylindrical area to get a good mesh but may not work for this problem:
on fully developed duct flow | yfyap | Main CFD Forum | 6 | November 7, 2012 09:59 |
Fully developed flow ,CEL expression | kmgraju | CFX | 0 | August 6, 2010 04:15 |
Fully developed flow profile | icfd | Main CFD Forum | 3 | May 20, 2009 22:21 |
Fully Developed Flow at an Inlet | Ed Mueller | CFX | 5 | January 13, 2009 11:50 |
profile for fully developed turbulent duct flow | jeff | Main CFD Forum | 1 | November 14, 2001 21:35 |
