Are Case and Data files enough?
Old   January 6, 2004, 21:03
Default Are Case and Data files enough?
Zhengcai Ye
Hi, Everyone,
Recently I have a question to ask costumer service of Fluent. They asked me to send them my case and data file. However, after they received my files, they told me some problems which never existed in my project. Obviously they did not get the same information as I did in my computer.
So, my question is whether only case and data files are enough for other people to read the correct information at other computers?
Thanks for your any suggestion!
Old   January 6, 2004, 23:41
Default Re: Are Case and Data files enough?
sijal
yes , coz u cas file contains u mesh and boundary conditions. and ur data file contains ur solution thats why it is enough to send the cas and data file
Old   January 7, 2004, 05:10
tom
If you are usign the non-premixed combustion model you would also have to send them your pdf file or if you are using a UDF you also need to send that as well, otherwise just the case and data file is enough.
Old   January 7, 2004, 13:22
DAE
Had the files been corrupted when you sent them? They should be sent by ftp using binary, not ASCII.
DAE
Old   January 7, 2004, 16:11
Zhengcai Ye
I sent them by email attachment (binary files). Does it cause any problem?
Thanks!
Old   January 7, 2004, 16:21
Zhengcai Ye
There is a UDF in my case file. When I sent them case and date files, I did not sent dll file. However I sent my source code of UDF. Does missing dll file cause any reading problem?
Actually when I tried to read case and data files without dll file, I will get error information as follows,
Opening library "libudf"...
Error: open_udf_library: The system cannot find the path specified.
Error Object: ()
However, when I use Define->User-Defined->Functions->Compiled to add and compile UDF, everything is OK in my computer.
So, in my opinion,missing dll file should not cause any reading problem. What about your opinion
Old   January 8, 2004, 05:02
DAE
No, shouldn't do, and u r cocrrect in that as long as you send the source code, they can recompile the UDF and everything should be ok.
Do you know what the error was that they were getting?
DAE
Writing Case and Data Files Using Journal/Scheme Files svp Fluent UDF and Scheme Programming 0 April 5, 2011 12:04
Video from case and data files girino FLUENT 9 March 29, 2010 03:41
getting data from case and data files mkrao FLUENT 2 February 10, 2009 01:11
fluent case n data files not exporting to tecplot krishna FLUENT 2 February 18, 2007 00:24
Structure of case and data files Frederic Nicolas FLUENT 1 August 4, 2000 12:54
