2D cylindrical problem in axial & radial direction
Old   January 4, 2004, 04:56
Default 2D cylindrical problem in axial & radial direction
Manoj
I have a 2D cylindrical geometry and I want to solve it in the axial and radial direction. In the gambit I can create the 2D geometry and export the mesh only in x-y plane & not in x-z plane. x-y direction means r-theta directions. but i want to solve it in r-z direction. anybody can please help me.
Old   January 5, 2004, 13:04
Default Re: 2D cylindrical problem in axial & radial direc
MN
Use the "AXIS" boundary condition to specify the center-line of your cylindrical geometry; this must lie on the Y-Z plane (ie along the x-axis). Then, when you import the mesh into FLUENT, make sure that you set the problem as 2D-axisymmetric (Define/Solver). In this way, the x-direction is your axial, the y-direction your radial coordinates.
Old   January 5, 2004, 13:10
ap
Do you mean you have an axisimmetrical geometry?
If so, you just need to choose the 2D solver and then choose the axi option.
Hi
ap
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
[Other] How can count the nodes in radial, axial direction in turbogrid? Saima ANSYS Meshing & Geometry 0 May 2, 2011 12:40
Problem with axial alignment in Turbomachinery zhaowei CFX 12 May 4, 2010 06:14
singularity problem in cylindrical coordinate dallybird Main CFD Forum 6 June 3, 2003 12:47
sweep problem ado Main CFD Forum 2 July 19, 2001 03:30
