Rotational effects for flow in disc cavities
Old   December 28, 2003, 10:57
Default Rotational effects for flow in disc cavities
Karthik
Hello all,
Could any one please guide me in giving the rotational effects to fluids in the disc cavities (discs rotating at around 15000 rpm).
1. Is the radial position of the fluid particles and the wall effects taken care automatically? 2.Or can we specify the rotational effect to the fluid zone through moving reference frame? If yes will it be taken for entire fluid zone near the stationary regions also?
Please clarify my doubt.
With Regards Karthik
Old   December 28, 2003, 12:05
Default Re: Rotational effects for flow in disc cavities
ashu
You specify the center of rotation and that takes care of radial position of rotating fluid. You may have to select either SRF, MRF or SMM model depending on your interest... I think Fluent has one tutorial on rotating discs...
Rotating Disc in a Volume of Air alcesalces OpenFOAM 15 March 18, 2011 09:08
Rotating Disc in a Volume of Air alcesalces FLOW-3D 5 August 28, 2009 18:04
Rotating Disc in a Volume of Air alcesalces Siemens 0 August 24, 2009 14:59
Solver for a Rotatinng Disc in a Volume of Air alcesalces Main CFD Forum 0 August 19, 2009 15:33
Heat convection into a Disc brake Robin Windram FLUENT 0 February 20, 2009 08:03
