Compute From
Old   December 27, 2003, 18:55
Default Compute From
co2
In the initialization pannel, in some of the fluent tutorials I have found that you often mention the compute from box to be some velocity inlet. what is the reason behind it? what if we dont mention this particular parameter?
Old   December 27, 2003, 19:09
Default Re: Compute From
ashu
can you explain the problem?
Old   December 27, 2003, 19:39
co2
problem is really simple where water is coming in from an inlet and has the pipe has two branches as the outlet .. the geometry is not that important i guess .. but my question was about the way solution is found out ..
why do we have to mention compute from in the initialization pannel?
Old   December 28, 2003, 11:51
ashu
you can start from know velocity field or start from zero condition. If you know the velocity at inlet and initialize the domain with that value, it would converge fast.....
How to compute the gradient of a scalar as a post-processing ayoros OpenFOAM Post-Processing 16 March 21, 2018 07:02
How do I compute the normal vector to a surface with FEM Vasilis Main CFD Forum 3 July 31, 2009 08:59
To compute Average flowfield with oodles flying OpenFOAM Running, Solving & CFD 3 May 5, 2009 09:46
How to compute liquid volume of the NOT whole domain snak OpenFOAM Post-Processing 4 June 25, 2008 08:34
How to compute an average slip velocity using DPM thomas FLUENT 0 February 9, 2004 09:17
