two step reaction modelling
Old   December 18, 2003, 06:55
Default two step reaction modelling
Ahmet Lotfoulahy
hi,
thank you for the time and effort spent to solve my problem. I am trying two step hydrogen combustion. But in fluent exist only one step hydrogen combustion. I want to two or three step hydrogen-air combustion mechanism modelling. the FLuent documentations gives no description
If anyone can help and build up a suitable answer, i would be very grateful.
Regards Ahmet
Old   December 18, 2003, 07:16
Default Re: two step reaction modelling
Ahmet Lotfoulahy
is there somebody for help? please, I would be very grateful.
Old   December 19, 2003, 13:38
MN
Presuming that you know the kinetics of the 2 or 3 step reaction mechanism, you can alter the hydrogen-air mixture reaction properties in order to modify and add new reactions.
Things that you will need to do include:
- Adding any intermediate species not already in the default H2/Air mixture to it that are needed by the advanced mechanism.
- Adding the second and third reactions, with appropriate stoichometry and reaction data.
- Modifying the first reaction to reflect the right species and stoichometry and reaction data.
- Modifying the mechanism to include the 2nd and 3rd step to make sure they are active along with the 1st.
Old   December 21, 2003, 10:00
Ahmet Lotfoulahy
hello MN thanks for reply But.What I not known two or three step hydrogen-air combustion reaction. I tried Thermo.db file change in fluent code database, but error has been occured in thermo.db file. I not define chemical special, because species button not disapper in fluent menu.
What am I add new reactions in fluent code? I forward to help about this proplems sincerely yours Ahmet
Time step size and max iterations per time step pUl| FLUENT 31 October 23, 2020 23:50
first step in species transport without reaction naus FLUENT 1 April 12, 2016 08:35
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
