Please Help! (Fluent Error)
Old   December 18, 2003, 00:50
Default Please Help! (Fluent Error)
John
Hi.
Sometimes, when I run iterations in Fluent 6.0, I obtain this error statement:
Error: > (greater-than):invalid argument [2]:wrong type [not a number] Error Object: nanOx7ffffe00
May i know what's the meaning of this error? How to resolve it??
Regards
Old   December 18, 2003, 05:20
Default Re: Please Help! (Fluent Error)
Erwin
I have seen the same thing. Very mysterious. It seems to have something to do with the residuals, but I don't know what. The only way I have managed to resolve is to initialize again and restart the calculations.
Old   December 18, 2003, 05:36
Andrew Garrard
When you recieve an error with NAN or not a number, it usually means that one on of the variables has increased to beyond the limits of FLUENT. It could mean that you have a divergent system do to one of the constants you set. Have a look at the residuals and see if one of them shoots up at the time of your error.
Old   December 18, 2003, 13:56
Erwin
I have a question for you: did this error occur after you repartitioned an existing case file and tried to continue the iterations??
Old   December 21, 2003, 07:48
Venkatesh
Did you got any warning message before getting this error message ? You will get this error message when the flow variables reach unrealistic values (eg: pressure reaching zero or density reaching zero). One way to handle is that limit the flow variable values with in limits( you will be have a rough idea of what the values of pressure ??).
And start the analysis with low under relaxation values ..
Old   January 5, 2004, 05:02
sijal ahmed
Venkatesh is quit right
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 06:17
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
