compression of dat files
Old   December 13, 2003, 11:59
Default compression of dat files
mateus
HI!
I have a problem with enormous quantity of .dat files - I'm doing an unsteady simulation, and each .dat file is about 50 Mb big. So I'm facing a problem of saving them (about 100 to 200) to cd or dvd. Is there any way (and how good is it) to compress dat files (like zip - does it work good - what's the compression ratio)? Or do I have to burn 10 cd-s or 2 dvd-s?
Thanks for your replies.
MATEUS
Old   December 13, 2003, 14:04
Default Re: compression of dat files
ap
I just did a trial with a 23 MB dat file and it has been compressed in a zip file of about 18 MB.
Maybe a bigger file can be compressed a bit more, but I don't think a lot.
Hi
ap
Old   December 14, 2003, 08:52
DAE
Hi
When saving the data files in:
file>autosave
append .gz onto the end of the filename
You can do this for both case and data files, and the result is that fluent will compress the file when it saves it, using gzip.
You can also do this when saving files in
file>write case
or
file>write case and data
This can be done on both unix and windows machines, but for windows, make sure that in your directory and filename, there are no spaces.
DAE
Old   December 14, 2003, 17:53
James Date
Have a go with WinRar you can get better compression ratio's than with winzip.
Regards James
Old   December 15, 2003, 05:23
mateus
Thanks guys!
I'll give it a try.
mateus
Compression of CFX results files famarcfd CFX 2 December 28, 2012 02:21
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
