UDF & Dynamic Mesh Tutorail Problem
Old   December 10, 2003, 11:56
Default UDF & Dynamic Mesh Tutorail Problem
Qureshi
Hi Everyone,
I have been trying to get my hands on the dynamic mesh tutorial in Fluent 6.1 but am unable to get forward from BUILDING the source file written in C. The message that I get on the console is some what like this
Couldn't find the specified file open_udf_libudf. Also it points out that "nmake is not a recognizable command"
I would be greatful to anyone who can help me with this.
Plus if any one can provide some tips on writing a UDF for a moving wall case. I have the equations and only have to integrate with solver.
Old   December 10, 2003, 18:37
Default Re: UDF & Dynamic Mesh Tutorail Problem
esteban
hi,
Do you have visual studio? You need it in order to use compiled udf's. I have the same problem and I have tried to change the udf into an interpreted udf (as I donīt have visual studio) but it's not straight forward. I have tried other compilers but it seems that it has to be visual studio...If you find a solution please let me know.
thanks.
Old   December 12, 2003, 05:18
emma
If you work with dynamic mesh modeling in windows platform, it's quite necessary that you have one c/c++ compiler, e.g.,visual c++ 6.0, this is the requisite with which you can work with dyn-mesh-modeling. Dyn-mesh-modeling can only be worked successfully with compiled udf, not interpreted udf!!!Another thing is, if all the necessary directories and files which you created in order to load in and build with your certain udf-library are all right built and put in the right place???
hope it helps a bit! Regards,
Emma
Old   December 15, 2003, 14:22
Big Stone
You can search the poster I once asked in the forum . It could be helpful to you
Old   January 15, 2004, 10:02
Qureshi
I installed MS Visual Studio 6 and all the problems are solved. Big Stone's comments and links helped in getting to the bottom of problem. Thanks Every one.
Old   February 5, 2004, 17:31
Cfdtoy
Hi Qureshi
Were you able to find the Valve.msh and Valve.c files for the tutorial. If so could you help me with the same ?
thanks
CFDtoy
Old   February 6, 2004, 04:52
Qureshi
I don't get you clearly. You mean to say that you are not able to find the files you mentioned or you couldn't open them in fluent?
Well these files come with the software and are contained in the folder tutorial file and further in dynamic mesh folder. You need to copy them to a separate folder for using them in Fluent instead of working with the original one. The folder also contains solution files and animation files.
Once you start the tutorial exercise, all the steps are very clearly mentioned and if you do it right you can run the tutorial easily. For using the UDF for this problem, you will first open the msh file and then follow the steps and once you reach the stage of calling in the UDF you will have to go to the folder where you had the *.c file copied, add it, build it, and then load it. Make sure that you have Microsoft Visual Studio 6 installed. And then follow the rest of the tutorial.
I hope I've coverd in some detail the problem's solution.
Take care & enjoy!
Qureshi
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
Dynamic mesh & Negative volume in 3D mahzironrazak FLUENT 97 December 28, 2020 23:09
Dynamic mesh for rotating wall - UDF ? Tobard FLUENT 1 April 28, 2011 19:00
[mesh manipulation] Dynamic Mesh Diffusivity Problem dancfd OpenFOAM Meshing & Mesh Conversion 0 August 29, 2010 12:50
dynamic mesh and udf problem boboroo FLUENT 1 January 20, 2008 22:26
