periodic flows and heat transfer?
Old   December 1, 2003, 10:17
Default periodic flows and heat transfer?
scarecrow
the model which has two inlet faces ,two outlet faces,and the ervry pair of inlet-outlet faces is defined as periodicity surfaces respectively.how to simulate this model by fluent? does it need UDF,and how ?
Old   December 1, 2003, 10:28
Default Re: periodic flows and heat transfer?
thomas
Hi, See thr online fluent documentation/tutorial/periodic flow and heat transfer. thomas
Old   December 2, 2003, 01:24
hbapply
Do not need the UDF, but before you mesh grid, you should link the faces that you want to define them periodic.
Old   December 2, 2003, 01:59
scarecrow
When the grid has been read into fluent,I need to input something such as mass flow rate ,flow direction and so on in the periodicity conditions panel.But how does fluent deal with these inputs to every pair periodic surfaces?
Heat transfer in oil (or other high Pr fluid) flows vishyaroon STAR-CCM+ 0 April 14, 2010 12:52
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
flow/heat transfer through heat sink (with fins)? Pei-Ying Hsieh Main CFD Forum 1 January 26, 2008 07:33
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 10:25
