Combustion-radiation
Old   November 28, 2003, 03:20
Default Combustion-radiation
Fred
Hi there, I use the DO model for the modelling of radiaition inside a rotary kiln. The solid phase of the rotary kiln is modelled elsewhere. It yields me profiles of volatiles mass flowrate, bed temperature, and kiln temperature. I use this profiles in order to fix Fluent Bondary conditions of the gas pahse. In fluent, I use k-Epsilon, PDF modelling and DO Radiaition. Well, in fact I want to compute the heat transfer to the kiln and to the bed. But in fluent, you have several choice : inciddent-raidiation, surface incident radiaition, radiaition hat-flux, total surface heat flux. No links seem to exist between these fluxes, and they diffr from several order of magnitudes. Does anybody has an explanation about the signifiance of these fluxes, and which one should I use. Thanking you in anticipation
Particles affecting radiation in combustion chamber bharath CFX 0 September 23, 2011 22:41
Multiphase radiation in CFX Luk_Fiz CFX 5 March 17, 2009 04:51
how to set radiation model for ch4 air combustion venkat FLUENT 2 May 9, 2007 11:13
combustion with radiation Tom FLUENT 1 August 30, 2006 13:20
thermal radiation and combustion roadracer Siemens 2 March 3, 2004 07:30
