November 25, 2003, 12:09 |
What is a facet value
Hi.
What is the difference between an average facet value and an average area value? Cheers Tom |
December 1, 2003, 13:51 |
Re: What is a facet value
A facet value is evaluated on the face of the cell, an average area weighted value is the average value on the selected surface.
Hi ap |
December 2, 2003, 05:21 |
Thank you for your answer.
The reason for the question is that I have an outlet surface. If I calculate the facet value for the surface and the average value for the surface I do not get the same result. Do you know why there is a difference? |
December 4, 2003, 13:48 |
I think it is like this.
Assume all your surface is composed of 3 faces of different area, i.e. 2, 3, 5 M^2. Assume the variable of your interest in these faces are 12, 15, and 18 Pa (assume pressure) Then: Average value based on surface area will be (2*12 +3*15 +5*18)/(2+3+5) Average facet value will be (12*1 +15*1 +18*1)/(1+1+1) where the number 1 reprents facet. |
Average Facet, Surface Vertex or Area-Weighted | Emmanuel | FLUENT | 3 | March 27, 2020 11:55 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 02:30 |
Vertex vs. Facet | delfel | FLUENT | 0 | August 13, 2009 19:10 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 16:57 |
facet average | Bob | FLUENT | 0 | June 3, 2004 15:08 |
