Separated Flow on Bluff Body
Old   November 18, 2003, 12:04
Default Separated Flow on Bluff Body
GPB
Hi, I'm comparing CFD predictions of flow over a cube against an equivalant set of measured data. I've tried standard k-e, Realz k-e, RNG and RSM models. For each I have tried Standard WF, Non-Equil WF and Enhanced Wall treatment. I am finding it impossible to accurately predict the separation bubble. Upstream the V profiles are o.k. but in most cases (except standard k-e which is too small)the separation bubble is prediced as too big, in some cases not even reattaching on the upper surface of the cube! This is a 3-D steady state calculation. I can't understand why the RSM is so inaccurate, and why FLUENT fails so badly in predicting such an underlying flow regime. I'm running out of time and ideas. Anyone got any thoughts/experience on this. Thanks.
Regards, G.
Numerical Solution of the Blunt Body in Supersonic Flow Problem andres17 Main CFD Forum 19 April 26, 2016 16:29
how to accelerate fluid in bluff body case? Rui Main CFD Forum 7 March 5, 2009 11:45
CFD of flow behind bluff body puneshwar verma FLUENT 1 January 1, 2007 14:20
Flow over Bluff bodies cfdguy Main CFD Forum 1 May 26, 2005 13:31
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
