transient natural gas flow in a single pipeline |
November 18, 2003, 07:15 |
Hi everybody I'm gonna model transient natural gas flow in a single pipeline. Is Fluent capable of modelling such kind of fluid flow? Is fluent powerful in the field of interior flows? How does it act upon compressibility? Please help me and let me now whether I'd better use Fluent for these purpose or not?
November 18, 2003, 07:37 |
Re: transient natural gas flow in a single pipelin
Hi; If in your gas flow there is not solid particles or solidification or other multiphase effects, your problem is very simple! For compressible calculation in the material pannel, set the density to ideal gas. Please describe more about transient effects. For transient calculation you need to set unsteady in the solve pannel. Regards
November 18, 2003, 08:27 |
Dear Roozbeh the flow I have in mind is under high pressure which is conventional for transmission lines i.e 300-1700 psig so it does not satisfy ideal gas state. and there are still many other questions unsolved, one of them is: can Fluent consider joul-thamson effect which plays an important role in cooling the gas or not?
November 18, 2003, 08:35 |
Heat transfer in the pipeline
November 18, 2003, 16:33 |
Re: Heat transfer in the pipeline
FLUENT implements the real gas model.
I don't know about the Joule-Thompson effect, but it shouldn't be difficult to implement it if not yet done. Hi ap |
November 25, 2003, 06:38 |
Hi
Fluent is the powerfull software in the field of interior and compressible flow, which most of the people recomend it. But to answer your question, please define your case more clear and give more information, then I might be helpful. |
April 2, 2012, 15:32 |
Ehsan Asgari
Rep Power: 18 |
I have a similar problem, Could you solve j-t effect modeling using fluent? |
Laminar gas flow under slight suction - transient works but not steady | audrey | CFX | 1 | September 8, 2011 20:43 |
Need advice on softwares working for dilute gas flow | Mason | Main CFD Forum | 4 | July 22, 2010 16:55 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 04:03 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
