Heat sink whith only natural convection
Old   November 16, 2003, 07:30
Default Heat sink whith only natural convection
Novello
Good morning, I would to simulate a particular geometry (3D) of heat sink whith onli natural convection, I'm a new user of CFD software (I don't have still never CFD software) and I want to understand if I must be assume laminar flow or turbolent flow. In your opinion are precise and reliable the results of Fluent software for this mixed natural convection/conduction in a metal problem?
Thanks Best regards Sorry for my bad English
Novello, Italy
Old   November 16, 2003, 21:14
Default Re: Heat sink whith only natural convection
Novello
sorry, my englysh is vary bad and you may don't understand my problem...
My problem is: I want to simulate an natural convection heat sink in air. I decide to use Fluent, which is the model to make in gambit? I think to create the model of heat sink (solid) ..and in which manner can I modeling the surrounding air?
Best regards
Novello, Italy
Old   November 17, 2003, 02:40
ashish
hello Novello,
In gambit, you have to model surrounding air as well by defining it as a fluid domain. And, You have to decide the size of surrounding fluid domain, based on how much volume of fluid surrounding the heat sink is getting affected by the natural convection currents.
Bye, ashish
Old   November 17, 2003, 07:46
Novello
Ok thanks, If V1 it's the volume of Aluminium heat sink and V2 it's a cubic larger volume that contain V1, I apply the boolean oparation V3=V2-V1, V3 is then the air volume and my system is constituted by V1 and V3. It's correct?
Thanks
Novello
Old   November 17, 2003, 07:59
ashish
Hello Novello,
Yes, it is correct...
Bye, ashish
Heat sink in natural convection Reunion STAR-CCM+ 5 September 30, 2011 12:20
model forced convection heat transfer on a heat sink farzad FLUENT 0 September 9, 2010 15:48
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 05:22
Forced convection heat transfer in heat sink Sidy FLUENT 1 October 18, 2008 04:27
natural convection heat sink D Sunil FLUENT 3 June 16, 2008 07:09
