I run a case and it looks converge from residual curve. All residual goes to decrease. However, it shows error "segmentation violation" and stops running every time when the iteration number is 249. I really don't know where this error comes from. What situation could cause this error and How many propability could cause that error? Is it the bug in FLUENT? Thanks.
Hi
There could be several reasons for segmentation violation. The primary one is: 'illegal acesss to Fluent's memory' by your case. At somewhere in your calculations, you are trying to access a location, where you are not supposed to. or If you are using UDMIs, not declaring the memories, leads to this type of error. Hope this helps, Chendhil |
I have run into this problem too. How can we solve that? It's also said " EOF on stderr" . I have no idea what it means. Please help me out. Regards
[ICEM] "segmentation violation" error | Jasmine | ANSYS Meshing & Geometry | 8 | January 16, 2015 05:00 |
UDF message error (SEGMENTATION VIOLATION" C_H_G | louiza | FLUENT | 0 | July 16, 2009 04:38 |
