high difference between cell and nodal values
Old   November 12, 2003, 01:21
Default high difference between cell and nodal values
Trilok
Recently i have completed a thermal analysis. while looking at the results, i found that there is huge difference in the results between the nodal and cell values of temperatures(around 40 degrees). What could be the mistake?. Is it the problem with the grid such as aspect ratio or skewness or something? Can anyone help me?? Thanks in advance Trilok
Old   November 12, 2003, 19:57
Default Re: high difference between cell and nodal values
Ajay Rao
Hi Trilok , Have you checked for grid convergence ? ( running the analysis for a finer mesh ) Have you checked for the total heat flux flowing in and out ? Let us know , what was wrong when you figure it out . Regards, Ajay
Old   November 13, 2003, 04:38
Trilok
This is a very very complex domain. so mesh check is not that much easy...i am sure that this problem can be overcome by with a finer mesh. For a similar kind of problem and with same mesh size i used to get a very less difference between nodal and cell values.This problem has occured with the current model only.coming to heat flux, mine is a radiation problem and it interacts with surrounding air also..so not possible to check heat flux... Thankyou for your help
Cell Reynolds Number laliong Main CFD Forum 12 September 17, 2019 04:18
Cell centered vs Nodal Data from Fluent prikeyma FLUENT 0 September 1, 2010 12:40
Ensight - node values -cell values leo FLUENT 1 May 12, 2010 09:47
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 13:04
nodal temperature values Mcgregor FLUENT 0 May 5, 2003 09:19
