November 10, 2003, 00:26 |
Local surface contour line plots
I have written a scheme script to create surface planes within a 3-d simulation domain and generate contour plots onto these surfaces. I am however unable to generate contour plots with the local variable values on the surfaces. the default 'global' values seem to be getting used all the time. is there some manner in which i can avoid this without having to calculate the local maxima and minima of the variable on the surface each time i wish to place a contour plot on it? regards Nandu |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 17, 2019 00:12 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 14:20 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 15, 2003 00:19 |
