different surface reactions at differnt wall?
Old   November 6, 2003, 12:42
Default different surface reactions at differnt wall?
jason
How can I define different surface reactions at different walls by UDF. Thanks.
Jason
Old   November 7, 2003, 06:59
Default Re: different surface reactions at differnt wall?
Andrew Garrard
I have not done this so I don't know if I am fully qualified to answer this question. But as noone else answered I thought I would hav a go. You can put a conditional statment into a DEFINE_SR_RATE macro something like:
if (!strcmp(r->name, "reaction-1")) {*rr = whatever you want;}
Where reaction-1 is the reaction ID in the reaction panel in the GUI. you can then select what reactions you want in the mechanisms panel and then you can set what mechanism you want on each reaction boundary. This is assuming you are on Fluent 6 - if not you should get it because it is very good for reaction modelling. I have not done this myself so let me know if it works out because I would be interested in finding out.
Old   November 9, 2003, 10:57
jason
Thanks. Your method will work on multiple reactions. But I want different reaction on different wall. For examples, only reaction 1 on wall A, reaction 2 and 3 on wall B, and so on. Maybe Fluent does not have this function.
Thanks again.
Old   November 10, 2003, 06:43
Andrew Garrard
using your example, could you not select reaction 1 to be in mechanism 1 and reactions 2 and 3 to be mechanism 2,then apply mechanism 1 to wall A and mechanism 2 to wall B?
Old   November 10, 2003, 12:17
jason
I can not find mechanism panel as you said. I'm using Fluent 6.0. In the wall panel of "defining BC", I can just select "surface reaction" in "Species". In the reaction panel of "material", I must define all 3 reactions there, and can not separate them by mechanism as you said.
Thanks
Old   November 10, 2003, 12:59
Andrew Garrard
define->materials->Material Type:mixture->mechanisms.
Old   November 10, 2003, 14:35
vculiu
Hi, Andrew,
What version of Fluent you are using? I do not have thsi option. I'm modeling a laminar flow with 3 wall reactions. In Material panel, I can not find this option. Here is a manual I'm also reading. http://p2chpd-cluster.univ-lyon1.fr/...g/node1059.htm
There is also no mechanism selection description. Thanks
Old   November 11, 2003, 05:58
Andrew Garrard
I am using 6.1.18. Maybe the mechanisms panel is not avaliable in 6.0. I assumed that it would be. I had a look in the fluent6.1 manual and there is a section in the index called reaction mechanisms. I looked in your manual and it is not there. I suggest getting Fluent 6.1. I don't know if there is a way of doing what you want without the reaction mechanisms panel, I would expect there would be, but I don't know how to do it. I would suggest the easiest soultion is to get 6.1.22 (which is the latest one) from the fluentusers website.
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Wall surface reaction problem llnudt FLUENT 0 March 14, 2007 10:43
wall surface reaction. help Emanuele De Bonis FLUENT 2 February 17, 2007 06:07
surface reactions on porous catalyst powder Dinesh Mantri FLUENT 1 October 24, 2005 04:53
Surface reactions in Species transport model Karthick FLUENT 0 May 26, 2004 06:24
