Symmetry and boundary conditions
Old   October 30, 2003, 07:39
Default Symmetry and boundary conditions
eric
I have values for mass flow rate for flow in a pipe, from which I calculate the inlet velocity.
I'm using symmetry, to reduce computation time, therefore i have half the domain of the pipe.
My question is - do I apply the full, calculated, inlet velocity as the boundary condition or do I halve the inlet velocity, because of the half pipe, and then double the values of the results?
Thanks in advance,
Eric.
Old   October 30, 2003, 07:49
Default Re: Symmetry and boundary conditions
David
no reason to half the inlet velocity, as you are using a symmetry and indicated it in your BCs.
cheers
David
Old   October 30, 2003, 10:52
ap
I agree with David.
You have to specify the real velocity inlet.
Old   August 30, 2012, 10:09
Default boundary condition (symmetry vs periodic doubt)
hhh
kunar
hhh is on a distinguished road
Dear friends,
i am doing 3D wing analysis, i have doubt on boundary conditions in fluent ie both symmetry and periodic, anybody have the answer please let me know briefly,for what kind of purpose to use symmetry & periodic boundary conditions, please tell any example with problem.
hhh is offline   Reply With Quote
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 03:18
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 08:21
Difference between periodicity and symmetry boundary conditions lost.identity Main CFD Forum 9 August 30, 2012 12:16
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
