Poisson's equation can be solved in Fluent?
Old   October 29, 2003, 16:47
Default Poisson's equation can be solved in Fluent?
Mark
Does someone know that a variable governed by the Poisson's equation can be solved in Fluent using UDF.
Thanks in advance.
Mark
Old   October 30, 2003, 09:05
Default Re: Poisson's equation can be solved in Fluent?
Andrew Garrard
I think you may want a UDS "User Defined Scalar" This solves poissons equation and there is a fair amount of information about it in the UDF manual
Old   October 30, 2003, 10:50
Mark
Hi Andrew,
Thank you for your message. But UDS is solved by N.S not Poisson Equation. Is it right?
Do you have any suggestion for that.
Mark
Old   October 30, 2003, 13:06
Andrew Garrard
I copied this out of the manual, does it help?
Flux Function is a drop-down list containing available functions for the convection term of the user-defined scalar transport equation(s).
none (the default) indicates that there is no convection term included in the scalar transport equation(s); i.e., you want to solve a Poisson equation instead of a convection/diffusion equation.
Old   October 30, 2003, 16:20
Mark
Hi Andrew,
Thank you very much,
It is very helpful.
Best regards,
Mark
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
Help needs regarding attach equation on Edge at Fluent darshankapadia FLUENT 0 November 17, 2010 07:05
Poisson equation solved with FFT HaKu Main CFD Forum 3 June 5, 2009 00:17
Fluent equation error?!? TOM FLUENT 6 July 15, 2002 04:24
Boundary conditions in a Poisson's equation? vincent Main CFD Forum 4 April 16, 1999 03:19
