Plot temperature profile
Old   October 29, 2003, 06:05
Default Plot temperature profile
David
does anyone know how to plot a temperature profile during the calculation?
I tried to use the plot command in the execute commands menu but it doesnt work.I know how to display a temperature contours this way but not how to plot it. I believe it should be straightforward, hopefully.
thank you very much for your answer(s)
David
Old   October 30, 2003, 07:22
Default Re: Plot temperature profile
David
noone knows how to plot a temperature profile during calculation in the execute commands menu?
if you know, please inform me
thanks
Old   October 30, 2003, 13:12
cp
Hi
The example on Fluent 6.0 Tutorial Chap. 15 (VOF Model) Sec. 7 describes how to plot the variation of 'axial velocity' during iteration. I think, you can use the same logic to get the temperature plot, if you would like to monitor the temperature at a point during simulation.
Hope this helps,
Chendhil.
Old   October 31, 2003, 07:30
Default Re: Injection point
David
Hi Chendhill,
thank you very much for your help.
However, it gives me a temperature plot in function of time when i want to get a temperature profile evolution during the iterations to see the influence of difference parameters I want to change.
I just found out i have to use animate functions which is very interactive and gives a lot of functions.
Concerning your problem with hollow spray I'm not sure, I have used DPM models but not spray but maybe you have to set your injection points on surface as you might have set it/them on the crown of your injector.
I might use this model later on, so if you didnt find or didn't get a proper answer and i get a clear answer I will let you know.
Hope this helps
thanks again and best regards
David
Old   July 24, 2017, 06:35
ashutosh jaiswal
ashutosh jaiswal is on a distinguished road
hey
i made a geometry of 2d flow between parallel plates. from graphics and animation i want to draw contour between temperature and total temperature. but it is not showing on the other hand velocity and stream function is showing clearly. can any tell me how i can plot total temperature profile
ashutosh jaiswal is offline   Reply With Quote
UDF for a horizontal temperature profile CD Fluent UDF and Scheme Programming 9 May 6, 2018 13:13
Please Help! Temperature profile UDF for 3D geometry subhankar_bhandari FLUENT 2 April 16, 2011 06:30
Help please! UDF for Temperature profile in 3D subhankar_bhandari Fluent UDF and Scheme Programming 2 August 16, 2010 09:37
how to set temperature profile in atmospheric boundary layer vickrenz FLUENT 0 September 16, 2009 14:26
velocity and temperature profile vickrenz FLUENT 0 August 31, 2009 00:58
