Equations in MS word?
Old   October 22, 2003, 07:45
Default Equations in MS word?
eric
I'm simulating turbulent, non premixed gas combustion using the eddy dissipation model.
This is very lazy of me but does anyone have a list of the consevation equations involved in this type of simulation, done in MSword. Either in equation editor or Mathtype.
It will take ages for me to type them into word, so if anybody already has a list of them done this would save me alot of time and pain.
If you could forward them to my email above that would be great!!!!
Thanks, I look forward to recieving the equations!
Eric
Old   October 22, 2003, 10:36
Default Re: Equations in MS word?
John Smith
I was thinking of replying to this post but it will take me ages to type in a response, i was just wondering if someone had a M$ Word file i could just post here instead?
Thanks ;-)
Old   October 23, 2003, 11:03
ap
If you can't do otherwise, you could scan your equations and insert them in your document, or cut them from an existing document and paste them as images in your work. I doubt however you'll obtain great results this way.
In FLUENT manual, in the tooltip text, you can also see LaTeX commands to reproduce the equation you're seeing, and MathType can import LaTeX.
Anyway, if you need to do a work with many equations, Word is not a good choice. You should switch to something more specific like LaTeX or Acrobat.
LaTeX is available on almost all Unix and Linux systems, with the name of teTeX. While a free and user-friendly LaTeX distribuition for Windows is MikTeX , which can be downloaded from www.miktek.org
Learning LaTeX requires little time but you'll recover it when you won't have to rearrange your document layout every times you insert an image or a footnote.
Hi
ap
Old   October 23, 2003, 11:52
cp
Good info ap,
Thanks,
Chendhil.
Old   October 23, 2003, 14:45
Default Thanks ap :-)
eric
Old   October 27, 2003, 10:38
mateus
Hi!
Just a simple question! I also use LaTeX for writing my reports, but Powerpoint for presentations. I copy paste equations in Powerpoint since i have no fun retyping them in equation editor. But the last time during my presentation all (well not all - thats also a bi wierd) the equation appeard upside down and mirrored...Well I managed to get out of the mess...Does anyone have a better solution for importing equations in Powerpoint. I know i should probabilly use pdf TeX for presentation but that's a problem if you have animations....
Old   October 27, 2003, 12:59
ap
If you use standard LaTeX commands and packages, you can directly compile your document to HTML, using LaTeX2Html.
All equations are saved as PNG images by LaTeX2Html, in a directory with the same name of your main document, located in the same directory where the main document was saved.
After compilation, you can easily import PNG images in Powerpoint.
Hi
ap
Old   November 2, 2003, 13:33
jx
That sounds very attractive. Thanks for the info, ap!
Old   November 16, 2003, 06:12
Easycad
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 04:19
Favre averaged Navier-Stokes equations help siw Main CFD Forum 3 June 24, 2016 12:26
Run time Selection Mechanism - Some help required to understand jaswi OpenFOAM Programming & Development 3 October 29, 2015 14:42
CFD governing equations m.gos Main CFD Forum 0 April 30, 2011 15:21
what is LaTeX ?? yfyap Main CFD Forum 28 September 6, 2002 13:01
