Porous media and convergence
Old   October 21, 2003, 23:09
Default Porous media and convergence
A.Joshi
If the porous media is inclined to the global coordinate system and we set the plane with plane tool and apply the coefficients for porous media. Flow is only one directional. There are multiple fans blow air into the porous media. The solution doesn't converge, fans converge to reverse flow. I have to first solve laminar flow and then turbulence and then porous media. This takes very long time. I'm using very large value of coeff. for the direction other than normal to flow. But with large value the flow doesn't converge, but it converges as I reduce it to the coeff. value similar to the flow direction. Any ideas how to solve the problem in one go???
Thanks, Ajoshi
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
porous media convergence help Brian FLUENT 6 February 22, 2012 06:44
Problems with convergence with an easy system franzdrs Main CFD Forum 0 June 15, 2009 19:17
physical velocity formulation and porous media KLG FLUENT 2 June 10, 2003 11:14
Modelling porous media adjacent to viscous flow Rina Lum Main CFD Forum 1 March 25, 2002 17:55
