Help on granular model
Old   October 7, 2003, 04:16
Default Help on granular model
Lohen
Hi, does someone evers use the granular model ?If so. I wanted to know if the viscoity in Properties for the solid corresponds to the granular solid viscosity !!
Thanx
Old   October 7, 2003, 15:16
Default Re: Help on granular model
ap
If you use the eulerian granular model based on the kinetic theory, the granular solid is considered as a fluid phase.
Its properties are specified in the Define->Phases panel, by selecting the granular solid phase and clicking on Set. Activating the Granular option, a group of parameters appears: Diameter, Granular viscosity, Granular Bulk viscosity, Frictional viscosity, Packing limit.
Hi
ap
Old   October 8, 2003, 12:33
Lohen
ok !! in the menu Display>Contours>Properties>molecular viscosity ..., for the solid in this menu, i wanted to if it is the computed solid viscosity from the different laws previously set in the granular model .
thanx again
Old   October 8, 2003, 13:17
ap
Sorry, I misunderstood your question.
The solid molecular viscosity you find in the Properties drop down menu should be the sum of all components of granular viscosity (collisional, kinetic, frictional).
In the solid phase definition panel, you specify
- Granular viscosity, which actually is the kinetic component of viscosity.
- Frictional viscosity
The collisional viscosity is always calculated according to Gidaspow et al. (1992) and Syamlal et al. (1993).
Hi
ap
Old   October 10, 2003, 04:26
Lohen
Yeah, ok thanks, that was what i was thinking !! It seems that you have ever used the granular model, have you already tested in a gas-liquid-solid flow and particualarly the value of the coefficient of restitution ess in such a flow !!
Thanks again !
Old   October 10, 2003, 13:19
ap
Yes, I'm working on the granular model for gas-solid flows because my goal is to develop a better model for risers.
I've never tested FLUENT granular model in a gas-liquid-solid system, anyway, as a first attempt, if e_ss is the particle-particle restitution coefficient, it should be the same you'd use in a gas-solid calculation, being related to solid material properties.
Hi
ap
Old   October 11, 2003, 14:22
Lohen
ok, it seems to me that the e_ss coefficient was used to tune the value of the dissipation of granular temperature (gamma_ls). I don't know the consequence of varying for a gas-liquid-solid flow where i think there are not so much collision between the particle, and the granular model did not take into account the properties of the continuous phase . What do you think ??
ThanX !
Old   October 12, 2003, 19:44
ap
Yes, you're right. The restitution coefficient takes into account the dissipation of the granular energy due to anelastic collisions between particles. It's also involved in the calculation of granular viscosity.
I think e_ss should be considered more as a physical property of the solid material rather than a model parameter. However, many models are too sensitive to the value of e_ss because the dissipation terms are bigger than the generation ones.
An important thing was noticed (Agrawal et al., Zheng et al.): the high sensitivity to e_ss is due to a not proper use of the kinetic theory, mainly related to the use of too coarse grids.
In order to obtain good results with the kinetic theory alone, cells of several particle diameter in size should be used, which is not possible with nowadays calculation resources.
So, to obtain good results on coarse grids, it's necessary to describe the particle phase turbulence using "sub-grids" models. In these models the micro-scale turbulence is described using the kinetic theory, while the meso-scale turbulence is described using a turbulence model based on mixing lenght or on the k-eps model (Hrenya-Sinclair; Zhang et al).
So I think e_ss is used as a tuning parameter only because models are not capable to properly describe the real behaviour of granular flows.
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
UDF for defining granular viscosity in mixture model priyanka.asp Fluent UDF and Scheme Programming 7 May 19, 2019 19:16
Eularian granular two phase model Kelly FLUENT 19 December 12, 2017 01:33
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 07:19
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
