animation sequence files
Old   October 6, 2003, 22:39
Default animation sequence files
solomon
I am simulating unsteady flow in a batch mode. I could not find the animation sequence file saved though I find the case and data files for each time step saved. To save the data file I used file-data-write command in the script that I am using to run the simulation in a batch mode .
I wonder if I have to add another command or any procedure to follow at the post processing stage inorder the simulation sequence file saved atomatically while fluent runs in batch mode.
Infact I follow the procedures to activate animation and it workd fine in the interactive mode the problem I have is to make the corresponding files saved automatically in a batch mode.
Thank You
Old   October 27, 2009, 07:14
Default animation in batch mode
khar nab
kharnabnew is on a distinguished road
Hi Solomon,
Did you get an answer conserning this issue? I am encountering the same problem.
Regards
kharnabnew is offline   Reply With Quote
Old   June 7, 2010, 18:18
Unhappy solve/animate/define/define-monitor
TDi
Tim Diller
TDi is on a distinguished road
I would love to find this out, too. I'm using Fluent12. I can get most of the way there but then get an error.
after inputing the option for Storage Path Name, I get the following error:
Error: No graphics functions are available.
Error Object: ()
Any help? Please?
TDi is offline   Reply With Quote
Old   June 7, 2010, 18:28
Default Text commands
khar nab
Hi all,
I am generating the snapshots using the text commands to set graphics with the appropriate views than save as hardcopy after setting the hardcopy format in the interactive mode.
I found that the Fluent text interface is much better that the GUI once we know how to use it
Good chance
Old   June 7, 2010, 18:48
TDi
Tim Diller
Are you using an input file?
Could you possibly post a sample of the commands or script that you would use to generate the images?
Originally Posted by kharnabnew View Post
Hi all,
Good chance
Old   June 7, 2010, 18:57
Default useful commands
khar nab
The commands should be something like
disp set-window number
disp set contour surface name or number
disp contour variable range
disp view restore-view view
disp view camera up-vector x y z
........... whatever you want as settings then
disp hard-copy name of file%-i or f or t.tif
Don't forget to set the hardcopy format in the file menu
once ghathered you need a software like quicktime pro for example to animate the single files
Regards
Old   April 3, 2024, 13:14
Default Ansys Fluent Post animation after calculation
Joćo Rodrigues
jgrodrigues is on a distinguished road
Dear all,
I'm doing some test simulations on Ansys Fluent and after finish calculations I have to make an animation of the result in Post (Results in workbench).
This animation sometimes take days and after that is another day to make the animation, between me finding out the simulation already finnished or it ends at middle of the night, there is a time wasted between.
Is there a way to make this animation automatically after ending calculations?
Via code or file etc
Thanks for your attention
Best Regards
Joćo Rodrigues
jgrodrigues is offline   Reply With Quote
Animation Sequence in Fluent with unsteady state Condition cycho FLUENT 6 July 26, 2014 07:53
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
