I am very new to combustion model, I don't know that which method will solve my simple problem of injecting LDO(It is a LDO fired Hot Air Generator) in combustion chamber... In real problem is to start the combustion, there is a spark plug to Ignite the fuel ... for Ignition what is to be used??
Thanks |
i suggest you use the tutorials first as you are new to combustion.
you can find the fluent tutorials on the following adress, though available in many other websites: http://www.cranfield.ac.uk/cww/ccc/d...tg/node159.htm i hope this helps dr |
hel (turbulent viscosity ratio limited) for supersonic combustion problem | omar.2002bh | FLUENT | 2 | September 5, 2012 11:04 |
Problem using EDM for combustion | nakul | FLUENT | 1 | August 11, 2011 05:01 |
A problem with combustion | Luk | Main CFD Forum | 1 | April 28, 2008 09:55 |
Combustion problem | rupal | CFX | 0 | April 21, 2008 05:29 |
problem in incomplete nonpremixed combustion | muro | FLUENT | 0 | September 28, 2007 06:54 |
