Modification of turb. viscosity using UDF?
Old   September 28, 2003, 16:48
Default Modification of turb. viscosity using UDF?
moon
If I use the standard k-e and the enhanced wall treatment for turbulence model, and define new turb. viscosity using UDF, What model will be changed?
is that standard k-e or wolfshtein's 1-eq. model in enhanced wall treatment?
thank you.
Old   September 29, 2003, 05:47
Default Re: Modification of turb. viscosity using UDF?
Martin
hi,
i had the same problem... with that udf you change the standard turbulent viscosity. on which problem you are working? perhaps we have the same...
Old   September 30, 2003, 15:20
moon
I used enhanced wall treatment for a pipe flow. but its prediction(skin friction, wall temp.) is so poor when reynolds number is small. so, I want to change the turb. viscosity as other equation. In this work, I have no idea, I'm sorry. now, I just want to know the possibility of that. If I get the idea from the forum, It will make me happy.
Old   October 1, 2003, 15:15
Martin
hi, sorry, i was wrong. you can change turbulent viscosity with udf. this new turbulent viskosity is computed for the whole domain (viscous affected region and fully turbulent). if you want different calculation in these two regions, you have to do on your own...
Old   October 2, 2003, 12:19
moon
In FLUENT, is new turbulent viscosity using UDF for the whole domain? I don't want different calculation in two regions. I just want to improve the prediction for a pipe flow. Can I get the information about the modification of turbulent viscosity for better result? for example, thesis, paper, book... except FLUENT manual.
UDF for Turbulent Viscosity Lourival Fluent UDF and Scheme Programming 3 October 13, 2012 04:09
viscosity in UDF! denhan FLUENT 0 April 6, 2007 02:12
VISCOSITY UDF AdN FLUENT 0 May 23, 2006 06:33
Help - UDF for solid shear viscosity nbh2801 FLUENT 0 April 21, 2006 08:49
UDF modification merac FLUENT 4 March 1, 2001 07:42
