Any other model instead of boussinesq model?
Old   September 25, 2003, 19:27
Default Any other model instead of boussinesq model?
moon
In manual, Boussinesq approximation is valid when beta*(T-T_0) << 1 and should not be used if the temperature differences are large.
@ beta : thermal expansion coefficient.
So, What model can I use for buoyancy-effected flow (ex, mixed convection with property variations) except Boussinesq approximation in FLUENT?
Old   September 26, 2003, 06:45
Default Re: Any other model instead of boussinesq model?
emre
If the pressure variations are small enough, you could use incompressible ideal gas model. It should be used when the flow is fully incompressible, then density is a function of temperature only, where for ideal gas model it is a function of pressure and temperature. Therefore you should specify the operating pressure for this model.
Regards emre
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 21:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 20:13
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
Boussinesq model reference temperature? David Agostinho CFX 2 July 4, 2004 12:55
