LES problem
Old   September 21, 2003, 20:55
Default LES problem
Jose
Can I use LES in a steady problem?
Jose
Old   September 25, 2003, 05:55
Default Re: LES problem
Chetan Kadakia
No. When running LES, it will be an unsteady. I'll explain why later.
Old   September 25, 2003, 08:10
thomas
Hey, The turbulence is a 3D and unsteady phenomena. Therefore it does not make a lot of sens to use LES in 2D or in steady case.
thomas
Old   September 26, 2003, 04:35
Chetan Kadakia
True it makes sense for 3d. But you can run some 2d analysis with it and get reasonable numbers. But the model has to be 2d in real life, and you it may not be accurate for some of the vortex stretching.
Old   September 26, 2003, 14:01
Default Re: LES problem and VOF
Jose
Thank you guys,
I am new using this model and I have to study a lot. I have another question I want to use the LES model with the VOF model to predict an interface water-air. The manual says that these two models are incompatible. I don't know why, I think is because the VOF model uses 1st descritisation scheme on time and LES uses second descritisation scheme on time, am I right?
Is correct to use the LES with a 1st descritisation scheme?
Thanks again.
Regards
Jose
Old   September 29, 2003, 06:04
thomas
Hey, I am not an expert but I do not think it is a question of discretization order. First your computational demand (time of calculation) will be infinite using those 2 models. A simple case using separatly LES or VOF already ask a huge time of calculation. Then I DO NOT KNOW your case but LES will solve directly Big structures of the turbulence and model the Small ones. Are you sure it make sens in your case to have such a degree of resolution when you just want to know the interface repartition between the 2 Phases which essentially depends on Big structure of the turbulence. So a simpler Turbulence model would seem enough to get valuable results.
Hope this will give you a further Idea. Regards, thomas.
Checkerboarding problem in LES Matteo85 OpenFOAM Running, Solving & CFD 3 September 15, 2012 23:15
problem with developing new LES solver Edison_Ge OpenFOAM 2 June 18, 2009 02:26
Checkerboarding problem in LES Matteo85 OpenFOAM Running, Solving & CFD 0 June 9, 2009 10:47
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
problem while looping over cells in LES Jimmy FLUENT 0 September 5, 2002 16:33
