coupled vs segregated solver
Old   September 17, 2003, 14:43
Default coupled vs segregated solver
sandeep
Has any one compared these two solvers for the same problem? I am trying to run a case( have run 70 iters so far on a 1 million mesh) and coupled -explicit solver shows me 0 pressure on a monitoring surface, while segregated-explicit solver shows me e6 pressure on the same surface. Is this fine?
sandeep
Old   September 18, 2003, 03:23
Default Re: coupled vs segregated solver
Ed
Hi sandeep,
solver settings are case sensitive, which means that you cannot use both solvers for the same problem. first you have to decide what kind of problem you want to solve and out of that information you choose the solver. coupled solver is for example a good joice if you would like to calculate compressible air flow with supersonic or even hypersonic velocities. seggregated solver is best used for incompressible flow calculations. this two examples should show you the varity of possibilities and therefore its the best to define the problem and to choose the right solver afterwards. mixing both would just confuse you.
have a nice day ed
Old   September 18, 2003, 10:04
sandeep
thanks for the reply, I have a mildly compressible liquid flow with low Re. Which solver would be best in your opinion
Old   September 18, 2003, 11:35
Ed
from my point of view, I would use the coupled solver.
Old   August 9, 2010, 04:53
Sam-CFD's Avatar
Sam Mathew
Sam-CFD is on a distinguished road
Originally Posted by sandeep
;108007
I would consider using only Segregated solver
Sam-CFD is offline   Reply With Quote
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 11:21
coupled solver wont work in star ccm+ richie Siemens 5 November 4, 2008 05:51
Convergence Definition of Segregated Solver Amir FLUENT 0 April 18, 2006 07:21
can use coupled solver to calculate combustion cfdfans FLUENT 0 November 25, 2003 05:48
coupled solver / uncoupled solver Jaan Unger Main CFD Forum 0 September 3, 2002 09:30
