September 16, 2003, 10:12 |
fluent: Text Command for Vector Display
I reply to my own mail..., which I haven't written in the good discussion (it belongs to "Gravity option in Fluent")
To define "Vector-Display" using Text Command with the option "Clip-to-Range" of the GUI, you can add .. /display/set/contours/clip-to-range? yes ... before /display/set/velocity-vectors/auto-scale? no /display/set/velocity-vectors/scale-head 0.1 /display/set/velocity-vectors/color-levels 20 ; /display/velocity-vector ; vector of velocity colored by velocity-magnitude ; minimum value (m/s) 0.0 ; maximum value (m/s) 0.5 ; Scale factor 2 ; Skip every 2 p.s. : It can be useful to add ... /display/set/velocity-vectors surfaces () ...in order to show vectors in the whole domain |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 07:47 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 12:55 |
Fluent: Text user interface | antallo | FLUENT | 2 | April 1, 2011 18:34 |
Problems with text command interface of Fluent | Pascal Anschau | FLUENT | 2 | November 9, 2005 08:25 |
