September 15, 2003, 21:21 |
Rotors and Propellers
I've seen Fluent, in its website, describing an application to a helicopter in hover. May I know what options it has for the modeling of the rotor? Is it actuator disc, or dynamic moving meshes fixed to the rotor? Thanks in advance |
September 18, 2003, 03:33 |
Re: Rotors and Propellers
It is modeled as an actuator disk by using blade-element theory. They used a user defined function to define flow properties on the disk representing the rotor blades. Regards Mustafa |
September 23, 2003, 21:26 |
May I know what parameters are involved in this function? |
September 24, 2003, 03:34 |
I think it is not available for common use(at least so far). May be you try to make it yourself. I dont think it is difficult. You just have to know balde-element theory. Regards, Mustafa |
Rotors and Propellers | Tank | Main CFD Forum | 0 | September 15, 2003 06:21 |
