Error: GENERAL-CAR-CDR: invalid argument
Old   September 11, 2003, 08:56
Default Error: GENERAL-CAR-CDR: invalid argument
Annie
HELLO, EVERYBODY!! WHEN I TRY TO SET BOUNDARY CONDITIONS FOR MY SOLID, THE WINDOW OPENS BUT ALSO I GET THE NEXT MESSAGE: Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: #f It seems tha doesn't cause me any trouble to continue....but is it really ok? If you know, please let me know.... thank you Annie
Old   September 11, 2003, 11:44
Default Re: Error: GENERAL-CAR-CDR: invalid argument
Erwin
Somewhere in your input a field is screwed up. Could for example happen if you read in boundary conditions from a previous Fluent version. It doesn't necessarily affect your case, but check each and every input item very carefully to see all is right. In that case you should be fine.
Old   September 11, 2003, 17:29
ap
It's not ok. If you continue, FLUENT doesn't consider the data you inserted and keeps the default values.
I obtained the same error if I set default settings in the Solve/Control/Solution panel, because pushing the Default button, in Fluent 6.0, the velocity coupling algorithm field is left blank. Pushing ok, FLUENT lost all my settings and used defaults.
Hi
ap
Old   September 12, 2003, 04:15
Annie
THANK YOU GUYS
Error: CDR: invalid argument [1]: wrong type [not a pair];Error Object: #f Perseu FLUENT 36 May 1, 2023 10:37
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
error: CDR: invalid argument [1]: wrong type Marc FLUENT 0 July 24, 2006 06:59
