material name of emissivity for a face thread
Old   September 3, 2003, 03:24
Default material name of emissivity for a face thread
Nici
Hello everybody and greetings from cold Finland
I would appricate if someone could help me to access either the material name or the emissivity of a wall thread within a UDF. Other solutions to distinguish beteween different wall boundaries are also welcome.
thank you in advance
Nici
Old   September 3, 2003, 04:45
Default Re: material name of emissivity for a face thread
Greg Perkins
below find some code I use to distinguish whether a thread is in a list of thread ids. It may not be super efficient but it works OK. Pass in an array of integers which have the ids - same as IDs in the boundary condition panel within the GUI. If the *thread is one of these then it returns the id else it returns NOT_WALL which you can define however.
For FLUENT 6 make sure you #define FLUENT_6 or if you only use 6.x remove the conditional compile from these lines.
Hope this is something like what you need.
Greg
IS THREAD
-------------------------------------------------------------------------- */ int is_thread_cm(Thread *thread, int no_threads, int thread_list[]) { #ifdef FLUENT_6 Domain *domain = Get_Domain(1); #endif
int i=0;
while ((i<no_threads) && (Lookup_Thread(domain,thread_list[i])!=thread)) i++;
if (Lookup_Thread(domain,thread_list[i])==thread)
return i;
else
return NOT_WALL; }
Old   September 3, 2003, 04:46
Greg Perkins
IS THREAD
int i=0;
while ((i<no_threads)&&(Lookup_Thread(domain,thread_list[i])!=thread)) i++;
return i;
else
return NOT_WALL; }
Old   September 3, 2003, 04:47
Greg Perkins
IS THREAD
int i=0;
while ((i_<_no_threads)&&(Lookup_Thread(domain,thread_li st[i])!=thread)) i++;
return i;
else
return NOT_WALL; }
Old   September 3, 2003, 04:48
Greg Perkins
Sorry had some trouble posting....this last one is the right code except in the while it should be while i lessthan no_threads (in C of course)
Old   September 3, 2003, 07:02
Nici
Hej Greg,
I solved the problem on my own even though it took a while! I found in the src.h macro appropriate for my purpouse
if (strcmp( THREAD_MATERIAL(f_t), char_bed) == 0)
where char_bed is defined as
char *char_bed = "ash"
All the other walls are steel so now I can distinguish between the char bed "wall" and steel "wall"!
Thank you again for your interest,
cheers Nici
Old   September 3, 2003, 13:21
Default how to add the second gradient of UDS
zhou
Hi,everybody How to add the second gradient of UDS(user defined scalar) into species equation as source terms. Thanks. I only find the macro in fluent to calculate the first gradient. By the way, is there any way to get the arrangment or distribution of cells in fluent? Thanks.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
