August 23, 2003, 13:29 |
torque calculation
Hi, I am to find the torque on a blade connected to the shaft. on force reports window what should i enter for moment center, axis direction of shaft or direction of flow, or what? What about pressure and viscous moments, am i going to add them up? pls note it is urgent. thanx baned
August 29, 2003, 13:53 |
Re: torque calculation
In the moment center you should enter the point that you want but you know what is better for you. In your case I`ll enter a point situated in the axis of the shaft.
torque calculation to find efficiency of fan | bhanu1810 | STAR-CCM+ | 5 | September 2, 2015 04:58 |
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 04:35 |
torque calculation | mach000 | CFX | 2 | April 14, 2010 05:00 |
Torque calculation in pumping equipment | Kirill | Main CFD Forum | 0 | June 26, 2007 17:59 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
